Tim_Ohio
# Posted: 22 Apr 2024 13:19
The internet is not giving easy answers to what might be the best wood filler to use on aged wood to fill cracks and holes before painting over with a new coat on exterior trim and wood columns. Do any of you have any suggestions based on your experience with the products?
Thanks to all that might respond.
Tim
# Posted: 22 Apr 2024 15:45
If it's outside and to be painted I would think a good paintable acrylic caulk would be suitable. It is what windows and doors are sealed with when it will be painted over. Just let it cure according to the directions.
# Posted: 22 Apr 2024 18:05
There is Marine Epoxy (iirc the West System); one of the few products Ive used that actually exceeded the claims. Pricey but worked on my vintage 1963 mahogany runabout.
spencerin
# Posted: 22 Apr 2024 22:00 - Edited by: spencerin
Is this for a cosmetic fix only? Or are you looking for something more durable/hard? If it's just cosmetic, stuff like Elmer's brand wood filler (a thick paste) will work. It'll dry hard, and then you can sand it as needed. If you need something more durable/hard, then you'll want an epoxy wood filler.
