Small Cabin Forum / General Forum / Wood Stuff
<< . 1 . 2 . 3 . 4 . 5 . >>
DRP
# Posted: 14 Oct 2025 08:34pm
I went in this morning and asked Alexa to play "oldies". She said "The play list 70's music coming up". I muttered "That ain't oldies". She muttered back "OK boomer".
In the late 50's /early 60's the Forest Products Labs was working on several research projects. One group created "Impreg", wood impregnated with some goo or other to strengthen and stabilize it. "Compreg" was another, compression and impregnation. The results were impressive, never seen either make it to market. There have been numerous others through the years, the silica impregnated fireproof stable wood, etc Hope for the best but price pressure is brutal. I imagine this is also more fire retardent at that high density. Like many dense jungle woods, probably need to predrill fasteners.
I imagine the teacup is check prone in that orientation, but really any orientation that uses the whole diameter of the stick. I guess basically it holds true, if the heart is in it, its probably a high risk stick.
DRP
# Posted: 26 Oct 2025 07:29am
I sawed some overripe pine logs yesterday and got into more pine sawyer grubs. Far better to fell and saw quickly, these sat all summer and became bug food. I thought I was making an 8x8 post but decided after showing the damage to just keep sawing boards for lumber pallets.
URL
# Posted: 26 Oct 2025 03:12pm
Noisy.
Opportunistic hungry bug-gers
DRP
# Posted: 31 Oct 2025 08:29pm
I think I did some stuff this week that will tie some loose ends together.
A poster asked about moisture content when things were "dry" in a green shell so he could apply finishes.
I pointed to this reference which gives Equilibrium Moisture Content for Wood around the world:
https://www.fpl.fs.usda.gov/documnts/fplrn/fplrn268.pdf
Look below, I'll find the table for the area closest to me. I broke into a pile yesterday, took it to work and metered it... let's see how close it is to the table. I actually don't know yet either, but its usually pretty close. I'm closest to Roanoke, VA, the wood is from Oct/ Nov, so air dry emc should be about 12.5%
Second pic is my stacks, I build pallet roofs to cover the piles, air dried but mostly not rain wetted... outside air under cover as per the tables.
Last pic is my meter in one of the boards off that open middle stack of 2x6's. The wood is fully air dried and at equilibrium with its environment, neither gaining nor losing moisture... the definition of the tables equilibrium moisture content.
Pretty darn close depending on which side of the mountain you're on, the science works.
And it was a pretty evening, he took me for a walk to the back 40.
# Posted: 31 Oct 2025 10:10pm
Quoting: DRP
the science works.
# Posted: 1 Nov 2025 03:30pm
I make assorted stuff from wood; stuff smaller than a cabin. Mostly for fun and a lot of things become gifts.
Here's an example. This used to be a short piece of S-P-F 2x6. After a glue-up and some time on the lathe it is about 4-1/2"diameter x 2-3/4" high.
1
1
2
2
3
3
4
4
DRP
# Posted: 2 Nov 2025 08:58am - Edited by: DRP
That's cool, the few times I've turned softwood it didn't end well. The most memorable was a cannonball bed post that popped off the centers. It rolled up one side, hit me in the head and rolled down the other, beat up by the ugly stick . Were you in a chuck or on a faceplate, or ?
# Posted: 2 Nov 2025 10:37am - Edited by: MtnDon
Start with a faceplate on the end that becomes the top. Turn the general outside shape and create a tenon for the chuck to grab at the other end.
Remove from the lathe. Remove faceplate. Install the 4 jaw chuck on lathe. Insert tenon into the chuck and close the jaws. Clean up the outside as the chuck centering is likely to be a slight bit different than the faceplate was.
Mount the drill chuck in the tailstock and bore a center hole almost as deep as the bowl interior finished dimension will be. Use a bowl gouge or carbide scrapers to hollow out the bowl.
Reverse the lathe direction and sand inside and outside. Grits 80, 120, 150, maybe 180. Softwood needs a lot more sanding than hardwoods.
When completed I secured the tenon end in the bench wood vice and used an Japanese pull saw to cut it off, then sanded the bottom on the bench sander. There is another way to use a jam chuck and the tailstock live center to remove the tenon with lathe tools, but I need to repair that jam chuck. Besides the softwood was easy to saw off.
There is also a jaw set (Cole's jaws) that can be used to grip the rim of the bowl with the tailstock used to hold pressure against the headstock/chuck. But I don't have one of those.
Sometimes the tenon is left there and maybe shortened a little.
# Posted: 2 Nov 2025 02:28pm - Edited by: MtnDon
FYI, here's a tenon from a different bowl. The 4 jaws of the chuck close and grip around it. This was a still wet chunk of wood; you can see how easily the jaws compressed the wet wood.
tenon
tenon
# Posted: 3 Nov 2025 07:21am
DRP those are interesting charts. Back in the years I ran my little custom woodworking shop. I always had to consider wood movement. And how to deal with it. And where in the world it may end up.
When I was gluing up a large table or desk top. They could move 1/4" during different seasons. I learned to use a sprung joint. Basically this. Say I'm doing a 4'×8' solid top table. And have 4' long glue joint. I will set my joiner up so it will cut the edges and leave a 1/8"-3/16" gap in the center. Ends touching. This creates a greater compression on the ends. This will help insure that the end grain won't eventually dry enough to split. I would buy1000 bd.ft at a time. Rough cut grade A. 8% moisture. And had to deal with a lot of crooked wood. Making the bows work against each other. One way then the next. And never used boards wider than 3" to maintain control of warp.
When turning on the lathe. After turning. Grap a handful of the shavings. Hold them against the turning spindle in the lathe. This is what I was taught burnishing is. The friction will heat the lignin in the wood cells and give you a nice finish.
I got into starting a wood shop because I just liked wood. And wanted to become a good custom furniture builder. Did a lot of really beautiful stuff. Kitchen cabinets if they let me get custom. Office desks. Bookshelves. Anything that customers could think up. Get up every day n go build something from wood. Did that for over 10 years.
Just walking through the woods n looking at every tree is enjoyable.
DRP
# Posted: 16 Nov 2025 10:40am
It's Christmas tree harvest time here, they are leaving the county by the tractor trailer load, about 4,000 at a time. The trailers lined up at the packing house coming from the fields hold around 400 baled trees. The shade cloth structure is to store them between harvest and loading if they need to hold them for any time. Usually they are packing and loading. The season started around Halloween and ends Thanksgiving. The crews will then head south to set the strawberries that were started here last spring. They will return in time to plant next years berries and then into the trees again for planting shearing, spraying and then harvest. The country stores get a whole lot quieter after turkey day.
DRP
# Posted: 18 Nov 2025 07:27am
This is a really good article on a year in the life of a pine tree... although it gets into a year in the life of any tree. The link I had went dead 20 years ago but just found another of his papers and backtracked, it's still out there, good stuff;
https://www.ltrr.arizona.edu/~hal/tyerlif3.pdf
DRP
# Posted: 30 Nov 2025 11:24am - Edited by: DRP
I think I showed the damage from oak timberworm a few pages ago. sort of a shotgun blast of holes of different diameters. The mature female beetle drills/chews a hole with her very long proboscis and then turns around, drops her ovipositor in the hole and deposits several eggs. These hatch into larvae that chew straight across the tree, hit the far side, turn around and return to the same area. The smaller holes are on the trip out and the larger ones on the maturing larvae's return. I had this picture from an oak timberframe job. We came back from a break and she had come to do damage to my timbers! After roughing out the joinery we dropped the timbers in a site built dip tray full of a borate solution. The larvae would not survive. If you look it up on bugwood or similar, the end of that long snout has a pair of wood chomping pincers to excavate that egg cavity. She is hard at work.
# Posted: 1 Dec 2025 06:04pm
Interesting info and image.
The family of the logger we had do the tree removal after the wildfire has been involved in logging in our mountains since about 1915. He is more than just some guy who cuts trees; he has a forestry science degree. He has some audio clips of White-spotted Sawyer Beetles doing their thing; a scrape - scrape - scrape sound.
DRP
# Posted: 11 Dec 2025 12:16pm
I've been enjoying this wood selection chapter of a 1920 Navy manual on airship construction. This was the era of wood and cloth, and what wood they were calling for!
https://www.loc.gov/resource/gdcmassbookdig.airplanesairship00tuck/?sp=71&st=image
DRP
# Posted: 5 Feb 2026 07:19pm
Attached is a pic of a piece of rafter. Happily the carpenter was young and quick. I've always known this as brown cubic rot, brown rot (intermittent wet "dry rot") vs white rot (constantly wet).
https://extension.psu.edu/brown-rot-in-wood
# Posted: 10 Feb 2026 03:17pm
The other day I picked up this chunk from who knows where and man, heavy as metal! My neighbor agreed, says it’s Iron Eucalypti. Skeptical I looked it up, really is such a thing.
# Posted: 10 Feb 2026 06:53pm
I think that needs to be made into something 'special'
DRP
# Posted: 10 Feb 2026 08:05pm
I think there are more eucalypts than oaks, well, looks like 742 species, and they are all out of my range. Is it this one?
https://kalanihardwoods.com/pages/ironbark-eucalyptus
If so I agree, it sounds like turning might be a good use if the size is amenable.
I like this site, you can go way down rabbit holes , this is his opening page on eucalypts;
http://hobbithouseinc.com/personal/woodpics/eucalypts.htm
DRP
# Posted: 2 Mar 2026 06:16pm
Trees don't poop.
Or do they.
Metabolism is going on, "food" is being consumed, sugars turn to energy. There are byproducts, spent fuel is being produced.
Every other creature on the planet takes one whiff of heartwood and knows exactly what it is smelling. Humans say "Doesn't that cedar smell good!"
Trees pack spent metabolites, and other poisons, into the heartwood, that is what kills those cells. It is often what makes the heartwood insect and decay resistant. Once those cells are backfilled and have died they are no longer part of the conductive tissue of the living plant. We heal, plants cover, major difference.
The sapwood is where the food is. I've attached a pic of bluestain, sapstain is another name. A sugar eating fungi, notice it knows where the food is.
2n'd pic is of powderpost beetle damage, I just hung out and stayed warm by that burning kneebrace. Again the beetles knew where the food was.
Someone mentioned deep penetrating finishes, that was a sales brochure . I have gotten borate in about 1/8" in a single application. That is the only "deep" penetration you can do DIY. Timbor for green wood or BoraCare for dry wood are the only things I have gotten in any appreciable depth. Borate is non toxic to mammals but disrupts insects and fungi. We used to get more heartwood, nowadays we get mostly sapwood. A dose of borate before finishing is not a bad idea.
# Posted: 2 Mar 2026 08:52pm - Edited by: MtnDon
Ah, bluestain. We have loads of ponderosa pine with bluestain. Sometimes it can be quite eyecatching in a finished product.
Two bowls made in Feb
7-1/2" diameter
7-1/2" diameter
ponderosa pine
ponderosa pine
9" diameter bowl
9" diameter bowl
about 100 yr. old ponderosa
DRP
# Posted: 3 Mar 2026 12:37pm
That's an incredible sapwood band, nice bowls too! I turned a couple of mallet heads out of some white oak firewood the other day.
Both sets of pics show that sapstain takes advantage of the rays to run in. It then punches through the pit pairs connecting the vertical cells to the horizontal ray cells and spreads out.
I've seen some mills sell bluestain as "denim pine". We had one log home client that really liked the look and asked the log home company to send him as much blue pine as possible. They were only too glad to oblige, it is a defect in most people's eyes. We had a fair amount of rain during construction and the stain bloomed, which can produce fruiting bodies with some spectacular colors. He decided to sand it and didn't wear a mask, not a good idea!
# Posted: 3 Mar 2026 08:36pm
Back home, the lumber yard I bought most wood at would sort through the T&G 1X pine and charge more for the blue stained boards. They called it silver pine.
# Posted: 6 Mar 2026 06:47pm
Blue stuff
DRP
# Posted: 6 Mar 2026 07:16pm
Beautiful!
hmm, look at that, it is lined up along a check or ray.
Scroll back up to my.. transverse section, above (the cutoff board). That band of blue in my board is the crosscut view of that band of your bloom
DRP
# Posted: 22 Mar 2026 02:26pm - Edited by: DRP
It rained overnight. This morning my wife was walking with the dog and came back up asking me to come look at some possible chestnut blight. Hmm, wrong host. I came back up and confirmed that eastern hophornbeam is not a host. So I started trying to figure out what it is.
Best I can tell it is Trentepohlia, an aero-terrestrial algae. It often forms a symbiotic relationship with lichen but I believe this is a free living one. This is from one article;
"Among the aero-terrestrial algae, the Trentepohliaceae are particularly well-adapted to habitats with high levels of air humidity. These habitats are also frequently colonized by species of lichen-forming fungi which form symbioses with trentepohlialean algae. Nelsen et al. (2011) estimated that approximately 23 % of all lichen-forming fungi are associated with trentepohlialean photobionts. "
The Wiki page on them is here;
https://en.wikipedia.org/wiki/Trentepohlia_(alga)
Named after a clergyman and scientist, quite common in the enlightened age.
Paul made a comment about one of his trees being an ironwood. Eastern Hophornbeam is also known as ironwood. I know of several others, always be mindful of common names.
# Posted: 22 Mar 2026 11:05pm
Trentepohliaceae...
Well, with humidity seldom higher than in the 20s (today had 8 hours in single digits) at least we won't have to worry about that.
# Posted: 25 Mar 2026 05:06pm
I’ve mentioned this before but since cutting firewood today… this jig is a necessity. Just 2x4s in an X. 5 cuts at a time, no bending over.
# Posted: 27 Mar 2026 12:04pm
Quoting: DRP
That chunk of wood still sitting by the bed. Weight still surprises me.
That guy is a wood worker too, makes nice household things. Here’s a few.
# Posted: 27 Mar 2026 03:27pm - Edited by: MtnDon
Oh Wow! #2 is shaking loose some memories. That appears to be what you can get when you harvest a walnut tree that was started with a graft of one type of walnut to another type in order to produce better nuts, IIRC. The wood becomes available as very old orchards remove trees. We saw some of that a few years back, in a shop in Point Reyes Station. The craftsman called it wedded wood. I wonder if this is the same thing, the same guy? We never met him, but he lived someplac nearby. He makes some very nice carved things.
