spencerin
# Posted: 8 Nov 2025 10:23am
Has any one tried this? I'm thinking of it as a "poor man's" version of 2-part (or 1-part) spray foam insulation.
For example - part 1 goes in one sprayer, part 2 in another sprayer, apply part 1 first, then spray part 2 onto part 1 to get the chemical reaction.....
# Posted: 8 Nov 2025 10:32am
What would be the advantage?
travellerw
# Posted: 8 Nov 2025 11:37am
No.. The 2 materials must be mixed thoroughly similar to mixing epoxy. If you did what you suggest there would be 2 problems. 1. The first chemical would just run down the wall and puddle at the bottom. 2. You would end up with a sticky mess that is near impossible to clean (requires acetone).
If you look at the nozzle on the spray foam kits you will understand. Its designed to mix the hell out of the chemicals before they exit.
spencerin
# Posted: 8 Nov 2025 12:16pm
Thanks, travellerw. gcrank1, cost - seems like the yield would've been much less expensive if it could've been done.
# Posted: 9 Nov 2025 07:13am
Use foam board and caned foam around it.
travellerw
# Posted: 9 Nov 2025 12:37pm
Quoting: Brettny Use foam board and caned foam around it.
This is the right solution. Get a foam gun and buy big cans online or at a contractor store. That would be the cheapest solution for a sealed foam insulation.
