Small Cabin Forum / General Forum / Advice Please
Jellikins99
# Posted: 19 Apr 2026 11:25am - Edited by: Jellikins99
Hi!
I have a 5x4m 44mm thick spruce Log Cabin that is my Man Cave & bar.
I have bought an optics bar to fit in the wall behind the bar as its centre piece. It weighs 14.5KG and I wanted to check that such weight on the walls will be ok?
I plan to use a french cleat system to attach and will hang it on one bracket only, so not across multiple rows to allow movememt etc.
Obviously, this is a lot of weight on one wall row and with some bottles and glasses on it, suspect may be up to 18 or 19kg in weight.
The cabin is obviously very solid, but any advice or experience gratefully received before i commence.
DRP
# Posted: 19 Apr 2026 01:31pm - Edited by: DRP
This is a stack of planks? I think that will take some pics and more construction info.
If the question is broken down to, "Will a 50 lb shelf hanging on a 16' piece of lumber stood up edgeways, want to twist that piece of lumber?" Absolutely, the desire to twist is there. What is resisting that desire to rotate?
As the span gets shorter the ability to resist that twisting is stronger. Is there a door or window buck making the horizontal log span shorter there. Is the shelf at midspan of a long timber or near a corner or buck that helps resist rotation. How wide are the planks and are they connected together by tongue and groove or splines, or, something to make the planks on either side share that torsion load.
Or, If the glasses start to slide, unload the shelf. Hmm, you can cleat to one log but have an unattached sliding leg that extends down past the next log edge but is free to slide.
Or, another way to think about design as affecting loading the wall, put the load in shear as much as possible. Securing a shallow cabinet by the top rail tightly to an upper course of logs, with the shelve(s) hanging down below. The load is hanging in shear much more than rotating.
Edit; below are a couple of thumbnails of shelves, the top hung one has less torsion on its mounts than the cantilevered shelf.
Provolone
# Posted: 13 May 2026 02:48pm
Honestly, you'll be fine with that setup. I've got a similar cabin build and those 44mm logs are surprisingly stout once they’re settled. 19kg is basically the weight of a heavy shelf or a small TV, and the spruce can definitely handle the vertical load. The French cleat is a smart move for weight distribution, but since you're sticking to a single log row to avoid pinning the timber together, just make sure you’re using decent-sized screws that won't bite too deep and poke through the exterior. I hung a heavy solid oak glassware rack on one of my walls last year using a similar method and it hasn't budged or caused any warping issues even with the seasonal shifts. Just mount it, level it out, and enjoy the bar!
branbin
# Posted: 7 Oct 2026 03:59am
Hi Jellikins99, the weight itself should be fine. The bigger concern is the optics bar trying to twist the log outward, as drp mentioned. I'd use the longest cleat that fits the log row so you can spread the screws out. A spacer block at the bottom that rests against the log below, without screwing into it, also helps take some of the leverage while still letting the logs settle. Then keep the heaviest bottles toward the back and give it a check after a few weeks.
