Small Cabin Forum / General Forum / Heat for small outhouse
. 1 . 2 . >>
Ejm
# Posted: 24 Aug 2026 01:00pm
Hello,
Looking for some help. I have a small 8x8 outhouse that I would like to heat so the pipes and toilet do not freeze. I would like to use propane with a thermostat, so it kicks on when needed. I see a few I could use but I am scared the oxygen depletion sensor would go off and shut my heater without knowing and everything would freeze. Do they make anything that does not have the sensor or something anyone could recommend for such a small space.
Thanks,
EJ
# Posted: 24 Aug 2026 05:11pm - Edited by: darz5150
Is it off grid. No electric?
I have at least 5 propane heaters with thermostats.
But all have the low O2 sensors.
Fanman
# Posted: 24 Aug 2026 07:48pm
Direct vent heaters don't have nor need O2 depletion sensors. Unvented propane heaters... well, if you like fumes and moisture in the heated space...
But, if the outhouse is well ventilated, it shouldn't be an issue.
Ejm
# Posted: 25 Aug 2026 08:40am
Good morning,
It has electric but limited on power, cant do electric heater.
I think it will have to be direct vent does anyone know one small enough for 8x8 room?
# Posted: 25 Aug 2026 09:08am
Any of the small (about 10"x10") elec heaters are enough to heat that and run on any basic 120vac 15amp circuit
Ejm
# Posted: 25 Aug 2026 09:10am
electric is limited, due to being on solar
# Posted: 25 Aug 2026 09:19am - Edited by: gcrank1
Direct vent fuel oil heater.
How deep are your feeder and sewer pipes in the ground; ie, you may keep the structure warm enough to not have the inside pipes freeze but if not deep enough in the ground......
Ejm
# Posted: 25 Aug 2026 09:29am
After thinking about it. I could use an electric heater that is efficient and has a thermostat that could be set as low as 45 degrees so it would not kick on too much. Let me know if anyone has a good electric heater that they could recommend.
Fanman
# Posted: 25 Aug 2026 09:50am
All electric heaters are 100% efficient. The power consumption will depend on how well the building is insulated (and on the outside air temperature, of course).
# Posted: 25 Aug 2026 11:54am
Tell us about your solar set up to better evaluate for you
Ejm
# Posted: 25 Aug 2026 12:20pm
I have the following...
- Victron 5000 watt 48 volt
- 3- batteries PHI-3.8-48-60-M 3.8kWh Lithium Ferro
- 8 solar panels: Q-Cells 400w Mono Solar Panels Model: Q.PEAK DUO L-G7.2 400
jsahara24
# Posted: 25 Aug 2026 12:47pm
I have a 500 watt ENVI heater that I use in my fishing lodge bedrooms. You can get them that plug into a regular outlet, or you can hardwire them. They also connect to Wifi so you can monitor and adjust the temps remotely. They mount to the wall so they don't look terrible like most space heaters. ~200$ when I bought them a couple years ago.
I'm not sure how it would work with your solar system especially if you are in a snowy climate?
I see some 8k BTU direct vent propane heaters which would probably be my choice if I was offgrid/solar.
philpom
# Posted: 25 Aug 2026 01:29pm
Thermostatically controlled heat tape uses 2-7 watts per foot. Apply it to the pipes and put a good insulation over the pipes.
Ejm
# Posted: 25 Aug 2026 01:39pm
was thinking about the heat tape but how would I keep the toilet tank water from freezing without keep adding antifreeze when we use it.
# Posted: 25 Aug 2026 05:22pm
And this is why we have a composting T
philpom
# Posted: 25 Aug 2026 06:14pm
You could do a heating pad on the back of the tank with insulation over it to force the heat in to the tank, maybe same for the underside of the bowl (12v or 24v best) and if it's used multiple times a day plus doesn't experience hard freezes this would probably work but for certainty you'll need some form of propane freeze guard.
This might work, can be wall mounted and permanently installed, flame less. https://www.walmart.com/ip/Camco-Olympian-RV-Wave-3-LP-Gas-Catalytic-Safety-Heater-Ad justable-1600-to-3000-BTU-Warms-130-Square-Feet-of-Space-Portable-and-Wall-Mountable/ 29764634
The issue is it doesn't have a thermostat so you'd need to rig something (safety). Turns out there are some agriculture freeze heaters but they are generally in the $1000 range or higher.
I'd add the heat tape no matter what.
philpom
# Posted: 25 Aug 2026 06:17pm
Outhouse for the boys, composting indoor toilet for the ladies.
# Posted: 25 Aug 2026 07:22pm
Or, 'out' for the boys, most of the time house not required
Imo 'we' waste far too much water running toilets for just liquids
# Posted: 25 Aug 2026 08:37pm
What happened "grin an' bare it" no matter the temperature?
# Posted: 25 Aug 2026 09:29pm
BTDT
A diy blue DOW styro seat made all the diff
# Posted: 25 Aug 2026 11:49pm
And no continuing expenses
# Posted: 26 Aug 2026 08:19am - Edited by: Brettny
After owning a composting toilet in a very well vented out building il never put one in my living space.
Do you live at this property?
# Posted: 26 Aug 2026 08:23am
Oh boy, toilet talk! My buddy heater sits right next to the toilet.
Ejm
# Posted: 26 Aug 2026 09:11am
It is a 3-season cabin in the Adirondacks. I shut it down end of December, but we would like to make a few winter trips, so trying to figure out of it is worth it.
I am leaning towards heat tape and an Envi electric heater, only 500 watts when running. I think my solar bank could handle it. Worst case maybe I will add another battery, there just so expensive.
# Posted: 26 Aug 2026 10:14am
Winterize it near the end of October and de winterize when in use. Theres really no other fool proof way for a few weekend trips.
We have a weekend cabin in central NY. Our winter plumbing is a foot operated pump from a 5gal water jug to a sink. Takes me 1min to winterize. I let my 5gal LCI water jugs freeze every winter.
If/when I have more indoor plumbing il be blowing out lines with compressed air and putting RV antifreeze in the toilet. 1gal of RV antifreeze is about $4. A new toilet is about $150. Not including any other plumbing. Piece of mind to.me.comes from it can all freeze and nothing will happen vs hoping the riged up heat will operate enough to keep from freezing. All it takes is a failed heater or dead solar system. Could be a frozen propane regulator to 3days of no sun. And I know the ADKs get alot of gray fall/winter days.
# Posted: 26 Aug 2026 10:45am
YES, that!
When it gets close to freezing overnight temps winterize the water 'system' and go to using the 5-6 gal 'bucket T' (the snap on T seat lids are available online or even Walmarts) with the liner bag. The 6gal buckets are taller if you need taller, available at home improvement stores.
Put a disposable diaper in the bottom of the bag to soak up the liquids. Btw, I recommend dbl bagging the bucket in case of a leaky primary liner.
Inexpensive and effective.
Ejm
# Posted: 26 Aug 2026 10:49am
what is the 5-6 bucket T?
Ejm
# Posted: 26 Aug 2026 10:59am
I get it, it's a bucket toilet lol the good old days.
spencerin
# Posted: 26 Aug 2026 11:34pm
Adding marine/RV/pink antifreeze to the toilet tank water is about as easy as winterization can get.....
travellerw
# Posted: 27 Aug 2026 02:11pm
Since this question had taken a bit of a turn, I will throw my solution in the mix.
We use an RV toilet. Winterize it, then if I'm lazy we just manually pour water in before use, if I'm not lazy I dewinterize it for the weekend. Works well for us.
. 1 . 2 . >>
