coach54
# Posted: 22 Apr 2025 02:09pm
I am building a 12 x 18 building on piers. I don't want to create cavities for ground guests.
I will be using laying joists 12 inch OC.
I am contemplating an initial floor of 1/2 osb, then a layer of Dri-Core Insul-Armor which is rated as a subfloor and has air channels on the bottom. Then topping it with 1/4in osb, then LVP with an insullated backing.
I imagine that this would be very solid and would retain enough heat.
thoughts?
spencerin
# Posted: 12 May 2025 02:10pm
DRICORE Insul-Armor says it has an R-value of 4.1. I would say, without knowing the location of the building, that this wouldn't retain as much heat (or cool) as you'd like. That said, it's possible to insulate beneath the floor at a higher R-value without creating cavities for undesirable "guests".....
travellerw
# Posted: 13 May 2025 11:35am
Are you building to code? If so, I'm pretty sure the 1/2" osb and 1/4" osb will not pass. At least up here 5/8" is required (and they required it for both the top and bottom of the sandwich).
Just an FYI, we built our cabin floor in a similar manner. Joists 16" OC, 5/8 OSB, 2" Foamular 400 XPS (bought used on marketplace), 5/8 OSB, LVP with foam backing.
We have stayed there at -40 and after everything warms up (about 24 hours), you can walk around in socks with no problem.
Stagger the OSB sheets so you don't have joints lining up from the top layer to the bottom layer. Use long screws and secure the top layer all the way into the joists. This makes a laminated floor that is super solid.
Grizzlyman
# Posted: 13 May 2025 01:23pm
I would think you’d want a higher r value using the foam sandwich approach traveler mentioned
# Posted: 13 May 2025 03:59pm
Depending upon location; ie, In da nort, get as much R as you can during the build. Just my 2c
travellerw
# Posted: 13 May 2025 05:44pm
Its pretty damn cold here and I have never wished for more floor insulation! The whole sandwich including the finish flooring puts me at an R value of about 12-13. Its actually one of the aspects of my build that I don't have some regrets. I call it a win if you can walk around in socks at -40
For walls and ceilings, yup stuff as much as you can. Even then, with the 2x8 gambrel roof I was only able to get like R25 up there. Its still enough that the heat pump can keep the building at +20 when its -20 outside (it can't get it there though, a big fire is required for that).
Its all a balancing act really. Money and logistics vs comfort.
CraftyNode
# Posted: 28 May 2025 10:45am
Some great insights here — thanks all. I've been researching different floor build-ups for pier cabins too, and came across an approach that uses engineered wood with integrated insulation layers, kind of like what travellerw mentioned with the Foamular.
One company I’ve looked into is Floorox — they specialize in wood flooring and subfloor solutions in the UK, and they’ve got some solid info on LVP options with insulation already built in. Might be worth checking out for material ideas if you're still in planning mode.
Definitely agree that staggering OSB layers and getting a decent R-value from the start is worth it. Cold floors are no joke.
# Posted: 28 May 2025 02:13pm
I cant see using Expensive pre-build products for a small cabin when you can diy on site for fairly cheap.
# Posted: 28 May 2025 04:44pm
CraftyNode thinks they're a crafty spammer
Tanner
# Posted: 10 Jun 2025 05:26pm
We built to code here in New Brunswick, CA. 16" on center 2x10's. R40 insulation. 3/4" subfloor. Sealed bottom (which is variously 16 to 20 inches off the ground) with 7/16" OSB to keep critters out. Heck of a floor! (Camp is 22x40; was a little expensive, but worth it). Gary
