Small Cabin Forum / Cabin Construction / Should I invest in an ERV/HRV or no?
utherjorge
# Posted: 8 Nov 2026 08:13am
Good morning again!
I just updated the cabin insulation post below; I need to do a better job of updating people who have given me good advice. I'm about to finish insulation of the cabin as stated in the thread below. In short, spray foam walls and ceiling, foam board in floor.
As for current heating/cooling, I have a portable window A/C-heat pump that's in place, and heats the place up well. It's a 12x16 cabin, so it's easy to do.
I have an 11,000 BTU propane direct vent heater that will be installed. I have it, but have had no chance to put it in yet. A/C obviously needs electric, but the propane does not.
I also have a dehumidifier running, but happily, it's been pretty dry at this time. Some small air leaks to sort.
The question is: should I invest in an ERV/HRV?
This will not be a regular residence. I hope to be there somewhat often, but it won't be a regular residence in the winter, but I expect to be there more in summer time.
There are four 36x48 sliding windows and a large sliding patio door with screen that all could be opened at any time.
Thoughts, folks? I appreciate your input ahead of time.
DRP
# Posted: 8 Nov 2026 10:22am
No, you are taking care of moisture. The energy savings will never balance the energy input
utherjorge
# Posted: 8 Nov 2026 10:31am
I don't plan to run the dehumidifier long term: I wanted to dry the place out for all the other work. I would like to use heater/A/C for that purpose. Is it small enough to still not need it?
# Posted: 9 Nov 2026 11:23am
Its 192sqft..I would not do an HRV.
Ours is 750sqft. We close it up tight when we leave with out issues. However we arnt wet mopping the place before we leave either. We do have a wood stove to heat so moisture isnt really a thing.
Peewee86
# Posted: 9 Nov 2026 06:49pm
I guess the first question is is this a permitted and built to code building? Code may require some sort of mechanical ventilation.
I put a small ERV unit in our place. In fact, it was the smallest and cheapest one that I could find anywhere on the market. It’s made by Panasonic and it’s not much bigger than a large bath fan. I have about $500 in to my set up. I think they’ve gone up a little bit. Panasonic makes a complementary duct piece so there is only one hole that goes out through the rim joist.
I wasn’t sure if I would need it, but the logic was small cabins don’t have a lot of extra space. This unit mounts in the ceiling joist cavity and is totally out of the way, but ready to go if needed. It would be much more difficult to run the wires and install one at a later time after the ceiling is in place.
909
# Posted: 9 Nov 2026 11:10pm
I'm running a Martin 8k BTU in 160 ft2 .The space is incredibly well insulated . A 20 lb propane tank lasts a month on average. During the worst winter weather, we're talking -30 degrees celcius (-22 F) , that same tank will last just under a week. I have zero need for a HRV in such a small space, or a desire more BTU's to consume more fuel.
We have 5VDC USB Powered Metal Portable 8" Desktop fans circulating air with the windows cracked at opposite ends to lower RH and introduce fresh air .
