# Posted: 3 Dec 2025 08:49am
Got back to the cabin late yesterday after a few days away*. It’s always cold in here first day, takes time to heat the structure and stuff inside. I’m a wood stove guy living in the forest so normally just wait for that to do the job. There is an LP wall heater I never use, crap around it and I forget how to even light it. So last night I brought in an empty 5 gallon tank that no longer runs the water heater but still ran a tank top heater. Still not convinced of the safety but it sure helped heat the place quickly along with the wood stove. Ran it for under an hour. Good way to burn the last bit of fuel in those tanks. Wife was worried the dog was going to fry himself but he knew better.
*Got rid of our 1996 Chevy S10 2wd. The state had a plan where you could turn in 1995-1999 vehicles for a 2,000$ buyback, an air pollution reduction thing. It had an engine knock and a few other old car things, so to the boneyard it went.
# Posted: 3 Dec 2025 09:35am
The quickest BTU Kicker to up the temps there is! LOTS of safety considerations to stay aware of including dont store it inside between uses, but you are a smart guy  So the state of CA is giving folks $2k to surrender 95-99 vehicles.....do they have to run/drive in to qualify?
# Posted: 3 Dec 2025 09:53am
Yeah, there are a couple things. First, you have to show registration, current and two years prior, pink in your name. I had a friend trailer it there, 50 miles away and worried it might throw a rod. But they only have you start and drive it in the parking lot.
# Posted: 3 Dec 2025 10:27am
I have used our 12kbtu mini split to help get the temps up in our cabin along with two 1500w electric heaters all ran via generator. After about 20min there doing nearly nothing compared to the wood stove. I dont even bother with anything but the wood stove now. I just put more kindling than normal in it. We have about 800 sqrt and can go from 32f to 65* in about 1hr. Keeping bedroom doors shut and a ceiling fan on really helps. Then when its 70f and the stove is still ripping you can open the bedroom doors and allow the whole place to equalize.
I believe those tank top heaters are 15kbtu?
philpom
# Posted: 12 Mar 2026 07:01pm
We face similar challenges when we show up after a few months and it's 15 degrees outside. As mentioned above by @Brettny I just break down some wood pretty small and get a roaring fire going pretty fast. Upstairs we have one of those fake electric heater fireplaces so we turn that on also. It was so cold one time you couldn't even feel the heat from it 4" away.
It's warm after a few hours but it can take 24 hours to get the building structure heated thoroughly.
# Posted: 13 Mar 2026 09:05am
Quoting: philpom It's warm after a few hours but it can take 24 hours to get the building structure heated thoroughly
Same here. Potable lp heater while the wood stove gets going. Usually only the first day while the structure gets heated, maybe briefly first thing in the morning if the night log burns out overnight.
I am getting a bit used to/spoiled by the easy lp heat. I can see why some folks give up on firewood heat, especially in a structure not accommodating to a wood stove. I do like the ambiance of a burning stove, and the excercise/cleanup of the dead wood laying around.
Fanman
# Posted: 14 Mar 2026 07:12pm
We have a wood stove and pretty much unlimited firewood, but the antique coal stove (a cylinder stove with a sheet metal body) in the bedroom heats up real fast. Two nights ago I was passing through and spent the night at the cabin, built a fire in the wood stove but never did might it.
travellerw
# Posted: 15 Mar 2026 12:02pm
At really cold temps (below -20C), we use the wood stove only. Within an hour we can make it comfortable near the stove. However, the rest of the cabin takes some time. We use fans to push the heat around (especially into the bedroom).
At -10C to -15C we will sometimes use the heat pump to help out! Really its just for fun as it can't come close to the BTUs the wood stove throws.
I have been toying with the idea of installing a diesel heater in the bedroom to help with heating that up. I say that, but it seems like a lot of work for the 8 or 9 times we are out there in the super cold.
# Posted: 15 Mar 2026 06:52pm
If you warm the bed before you get into it to sleep, the bedroom itself doesn't need to be heated as high. We have used an electric blanket to heat the bed before we go to sleep for years. The electric blanket is under the comforter. Our PV and battery storage system has never had a problem with us doing that.
