kittysmitty
# Posted: 6 Sep 2026 07:13am
I always take a 5 gallon jug of drinking water to the camp. I just thought about sanitizing my jug. I fill it with municipal water that is treated with chlorine. Is that sufficient or do I need to clean the jug with bleach? Thanks
Fanman
# Posted: 6 Sep 2026 09:59am
I just rinse the jugs with hot water before filling them (with well water, not chlorinated city water).
If I'm bringing water to leave for an extended time (during the winter when I'm not there as often), I'll buy new jugs of spring water.
spencerin
# Posted: 6 Sep 2026 10:15am
If you're trying to truly sanitize it, use bleach or even just dish soap. If you use bleach, make sure it's properly diluted (but still effective).
# Posted: 6 Sep 2026 05:58pm - Edited by: MtnDon
Washing the container with warm soapy water using a brush that may be inserted has worked for us for decades, both for water carrying and beer or wine making. Soaking for an hour or two with a solution of water and Oxy-Clean helps clean out the post-brewing debris. There are long handled brushes made specifically for washing out 5 gallon carboys that are used for wine and beer making. Home brewer supply stores and Amazon have the brushes.
# Posted: 6 Sep 2026 07:35pm
I have 5gal jugs that I fill with my well water. I may rinse them every few trips but almost never soap anymore. I have 7 and only use maybe 2 a trip so loose track of what ones where washed. I have LCI military jugs and let them freeze all winter and have for about 5yrs. Not one issue with them. They where about $23 new about 7yrs ago.
# Posted: 7 Sep 2026 07:24am
I have about 10 jugs in rotation, at the filling station I give them a quick rinse. Usually bring a couple home at the end of a trip and those I will give a bleach rinse before refilling, but I don't keep track of jugs so who knows how long some have went. As long as they aren't in the sun, water doesn't really go bad.
# Posted: 7 Sep 2026 09:51am
We dont have potable at cabin but pick up such at a city maintained & tested artesian well en-route. The cabin has a 2.5gal ss jug and our normal refill jug is an old 2.5gal Coleman. About every other cabin trip we get fresh water and the 'old' in the ss gets relegated to a utility jug for dishwashing, etc. Usually the ss gets a hot soapy dishwater scrub out a couple times a season. The Coleman jug gets dried well in the sun on the front steps and never left wet inside. It gets a fresh water quick rinse before each filling. It gets the scrub out in the spring and whenever I feel like it in season. We have been doing it like this for about 40yrs, no issues yet.
The real milo
# Posted: 14 Nov 2026 08:53am
Municipal chlorine keeps the water itself safe briefly though it is not concentrated enough to remove biofilm that builds up inside reused plastic jugs. Every few months you should scrub the jug with warm dish soap rinse well and sanitize using one teaspoon of plain unscented bleach per gallon of water. Let that solution sit briefly drain and air dry completely.
travellerw
# Posted: 14 Nov 2026 01:12pm
I don't bother scrubbing, but I do a thorough rinse about every 3 trips. I then sanitize with Star San (I always have some mixed up for brewing). Empty Star San and fill.
Although I think it may be overkill if you are using city water with chlorine and seal the container between uses.
DRP
# Posted: 14 Nov 2026 04:59pm
To add another non chlorine sanitizer B brite is brewers percarbonate where starsan is phosphoric acid. I like the idea of brewers cleaners for water vs Clorox.
# Posted: 14 Nov 2026 05:26pm - Edited by: gcrank1
me too  Water, dont leave home without it
travellerw
# Posted: 15 Nov 2026 12:40am
Quoting: DRP To add another non chlorine sanitizer B brite is brewers percarbonate where starsan is phosphoric acid. I like the idea of brewers cleaners for water vs Clorox.
Phosphoric acid is an amazing chemical. From a sanitizer, to a rust converter, to a wood cleaner, to a concrete etchant, to a rust remover (our goto on the boat, excellent for removing rust stains from fiberglass), to a toilet bowl cleaner. In low concentrations is safer to consume than bleach. Just good stuff.
909
# Posted: 15 Nov 2026 02:58am
https://www.youtube.com/watch?v=hytY9JwK9yc&t=14s
Bleach is perfectly safe if you rinse it really well.
We also use local treated spring water for everything.
# Posted: 15 Nov 2026 05:21am
I saved the Arizona Ice Tea containers, thick plastic. 1 Gal each. I rinse with 50/50 bleach and water. Then rinse again. I take 6 gallons to the mountain.
