travellerw
# Posted: 9 Oct 2025 10:57pm
Ok.. I know there are some Alaskan cabin owners here that must deal with the same thing. Flies.. soooooo many flies...
We haven't been to the cabin in 6 weeks and when we arrived today there was a 1 fly thick layer of dead flies EVERYWHERE. As gross as it sounds, its not uncommon for cabin owners around here to have this issue (even home owners). Black flies in the fall and spring is just the norm here.
What I can't figure out is how they get in. We sealed the living crap out of this building when we built it. The only thing I can think of is the windows. They are absolutely getting behind the screens as I see tons between the screen and window. I'm guessing they are somehow getting through the closed window seals. I plan to seal off the windows using plastic shrink film in the spring. That way I can see how many are actually coming through the windows.
However, I'm sure you smart fellas could suggest other places they may be getting in! Suggestions?
# Posted: 10 Oct 2025 10:41am
Ironic. We don't have a ton of them here but two or three will come in the cabin door if left open. Thought I had flypaper but cant find it. Stopped at both HF and Dollar Plus, don't carry it. Never seemed to work that well anyway. I have a small usb zapper, rare day when it gets one.
DRP
# Posted: 10 Oct 2025 05:32pm
Sounds like cluster flies, look that name up for control ideas. It also sounds like they are not only coming in, they are home, eggs, the whole life cycle can move into the cracks and crevices with you. Log homes are notorious but we also had trouble with a house that had a huge stone dry stack look chimney and fireplace, it was a high rise development for them.
# Posted: 13 Oct 2025 12:06pm
I have flys in my cabin every fall-spring. When I warm it up they all come out. I have found sticky window traps on each window really help. It's been 2yrs and the population is slowly going down. I also vac up all the live ones I can when I'm there.
SCSJeff
# Posted: 14 Oct 2025 02:18pm
I don't love this idea... but, I've done it twice over the 10 years in our cabin:
Bug bomb. Each time I did it, I had dramatically fewer flies for a couple of years
I only did it on the 2nd floor (where most of the flies and wasps are). So not directly near the kitchen area
travellerw
# Posted: 14 Oct 2025 03:28pm
Thanks everyone..
We have put up removable plastic on the insides of our windows. We will see how that works. I'm pretty sure that %99 are getting in through the windows.
I like the bug bomb suggestion. I'm not above chemical warfare. I also use the vac to suck the suckers up.
# Posted: 15 Oct 2025 07:51am
I think once they get in they multiply and hide in many places. I dont believe all the ones you see come in from outside.
UpNorth48
# Posted: 7 Nov 2025 11:38pm
We have MOSQUITOES... I mean lot of mosquitoes. Very rural Northern Ontario, Canada. This year was particularly wet and bad for da bugs. I managed to get them to a dull roar inside over the years addressing cracks around screens etc. but could not eliminate them... my 12 year battle after we rebuilt after a forest fire. I knew there were a few coming down the chimney of the demand water heater, nothing I could do about that. BUT... this summer I found the major source. In the wood stove, there would be 100's in the morning. Airtight wood stoves do not totally seal with the door/vents, there is a secondary vent that is unregulated. Ours is under the lip of the ash tray... about 1.5" square. One piece of paper towel solved 90% of the skeeter problem. Hope this might help others. Regards from the North: Dan
# Posted: 8 Nov 2025 07:48am
I was up at camp last weekend. Many many flys again. The window traps did catch some. You could kill everyone on the windows with a fly swatter..come back 30min later and get nearly the same amount. Did this for 2 days and it did help but not greatly.
# Posted: 9 Nov 2025 02:30pm
A friend at church this morning mentioned their northern WI small cabin had a huge bunch 2 wks ago. They started the wood store to take the chill off and warmed up the flys that took over the place. He pulled out his bug zapper for their deck and hung it inside, turned off the lights and they went for a walk. It did zap most but left quite a smell......He stuck it in a garbage bag and brought home to clean with the water hose (well driller missed getting their well in back before winter of '24 and has missed by Oct '25 now to).
travellerw
# Posted: 10 Nov 2025 11:08am
Well, it was the windows! We covered all the windows in plastic (on the inside) and the fly problem is solved. We only had a few which I think were born inside from the previous flyapalooza.
Since I'm not super keen on having plastic on the inside of the windows, I'm going to look for another solution. It seems they are getting around the screen as there is always flies between the screen and window. Once behind the screen they are finding their way in.
My plan is to seal the screens on the outside all the way around (they are removable screens). However, I'm not sure what to use. I want to use a tape of some sort, but it has to stand up as I don't want to be replacing it often. Any suggestions?
