Small Cabin Forum / Cabin Construction / Board and batten
<< . 1 . 2 .
meetkaneadam
# Posted: 5 Nov 2026 05:21am
One thing worth considering for anyone planning a similar cabin interior is the material takeoff before purchasing the plywood and battens. Since carrying materials to a remote cabin can be a lot of work, getting the quantities right upfront can save both money and unnecessary trips.
For the paneling, I'd calculate the total wall area first, subtract large openings such as doors and windows, and then add a reasonable allowance for offcuts and mistakes. For the battens, measure the total linear footage needed based on wall height and spacing, including corners and any additional trim.
If you're planning to rip your own battens from wider lumber rather than buying pre-cut strips, remember to account for saw kerf, knots, and unusable sections. Also, let the wood acclimate to the cabin's interior conditions before installation to help minimize movement after painting.
For anyone who needs to convert lumber dimensions and linear footage into board feet when estimating material quantities, this Board Footage Calculator can be a handy tool.
And looking back at Grizzlyman's final update, the 1/4-inch birch plywood with 1/4 × 2½-inch battens turned out to be a successful lightweight solution for that particular cabin. It's a useful real-world example of why testing a small section before committing to all the walls is worthwhile.
DRP
# Posted: 5 Nov 2026 09:07pm - Edited by: DRP
meetkaneadam.. tell us about yourself, your about us page kind of failed to tell us about you.
Reading the comments above about waviness, remember almost all sheet goods have a "strength axis" even drywall and OSB (ORIENTED strand board). The length should cross the supports for maximum strength, or lack of waviness. That is one reason for furring out or blocking a wall or ceiling.
<< . 1 . 2 .
