Small Cabin Forum / Off-Grid Living / Humsienk 12v 314Ah Mini BT
<< . 1 . 2 .
# Posted: 12 Apr 2026 01:21pm
There really is no need or benefit to going above 3.500VPC / 14.0V as the chemistry will settle to 3.400VPC +/- 0.050V pending if there is load or if allowed to settle without.
Remember the difference between "Allowable Voltage Range (2.500-3.650)" compared to "Working Voltage Range (3.000-3.400) which can be safely extended to (2.800-3.400)" volts per cell.
A "Surface" charge where Amps Taken remain high will not provide full saturation to that Voltage Level. If you charge to 14.0V and the amps drop to <5A then the cells are "saturated" to that voltage and you get everything back out. Without that Full saturation, its like driving on a 1/2 full tires while hoping for great mileage (never gonna happen).
# Posted: 21 Apr 2026 12:29pm
WiFi on I can look at the cabin from afar. I doubt it will last all weekend but maybe 100 hours.
So we were at the house 4 days with the Humsienk powering the camera WiFi starting at only 13.2-3 charge. Watched the cabin all weekend until Monday, no connection. Got back to the cabin, Hummer at 2 volts. Jumpered it to the bank, shot back up. I guess I can do that on a regular basis?
<< . 1 . 2 .
