| << . 1 . 2 . 3 . 4 . 5 . 6 . 7 . 8 . >> |
travellerw
# Posted: 18 Mar 2026 11:05am
Quoting: jsahara24 How did the cushion valve change the machine? Its definitely "jerky" but I'm getting used to it the more I use it..
The cushion valve doesn't really change how the machine works. Its more for protection of the slew motor. It essentially adds a small amount of cushion at the end of travel when you spin the machine with a load of dirt. Guys were stripping gears or completely breaking off the slew motors.
For the "jerkiness", you can add springs or small piece of fuel line to the pilot control plungers. It helps for sure, but doesn't completely tame the bronco. Some people will slow things down by adjusting the pressure on the pilot controls. Basically turn it down until the machine doesn't move, then slowly increase it until its where you want it.
A fan will help to solve your gas boiling problem. However, I suggest you keep a close eye on you hydraulic oil temps. 140F (60C) is bad and the oil degrades quickly at those temps. You want to make sure you keep it below that.
# Posted: 19 Mar 2026 11:03am
Quoting: darz5150 bought quite a few of the Amazon basic rechargeable double and triple A's. They've been doing good for a few years. Better than
Just bought another 8 pack of those AA Minh. The first ones have been in the smoke detector over a month. The old alkys would start the low voltage warning beep after a week or two. They were just those dollar store alkys, not sure who makes or sells good ones anymore. The local radio shack is long gone.
# Posted: 19 Mar 2026 11:17am
Hopefully they work out for you. I like them. That new smart charger seems to work well also. Kinda handy if you need to charge a single battery or an odd number. The cheap led lights I got off temu are doing good too. I am using 2 of them on sensor mode. I've only charged them once.
# Posted: 19 Mar 2026 11:25am
Glad to see you got another drone. Handy for checking the roof too. How's Buddy like it?
# Posted: 19 Mar 2026 11:44am
I have a couple sensor LEDs, the old HF solar ones. But the solar part is long gone, just have them plugged into USB’s. One in the bathroom, one in the living room and one out front.
Haven’t gotten good enough controlling the drone to hassle the dog yet. Getting a bit better but it’s a real learning thing. I have a long range plan to fly it way up over my tree tops with a string attached and back down over a branch so I can hoist a cord up there with a TV antenna. The end result I can almost guarantee will be a drone permanently stuck way up there.
# Posted: 19 Mar 2026 03:17pm
If your going to do a Kamikaze run. My son picked up a couple drones from the 5 below store for $10 or $15 bucks. That are exactly like the ones we paid $40 bucks for. That way you might only have $10 bucks hanging in the tree. Lol
# Posted: 20 Mar 2026 11:25am
I’ll check it out. We have a $5 store right next to HF. Never been in it but I pushed the wife inside while I went to HF. She spent more than I did! Some store employee pushed her up and down every isle.
Just pulled this old drone out. Think I got it at the flea market years ago. It has a usb port, pre-C, but the controller takes AAAs. It’s only about 6” across, half the new one. As I recall it had a mind of its own, couldn’t control it. We’ll see, it’s charging now. The new one said it will climb 200’, which would get it over the trees.
# Posted: 22 Mar 2026 10:43am
Some progress. A friend, who can see and walk better, took the new drone up and over the trees and back down, while I manned a fishing pole and line tied to it. It goes over a branch about 125’ up. We tried again for a higher branch but the drone battery died.
Good enough to hoist a TV antenna and coax cable up. I’ve ordered 200’ of coax, hope the signal can travel that far.
# Posted: 22 Mar 2026 12:22pm
Good for you Paul.  You can add a signal booster if needed probably.
# Posted: 22 Mar 2026 02:06pm
Quoting: darz5150 signal booster
Yeah that’s another thing. I’m going to try the same antenna as at the house, one of those $35 jobs we’ve talked about. They come with a booster. At the house it’s about 30’ from antenna to the booster, another 30 the tv.
I read that boosters should be close to the antenna. I guess they boost from the antenna down the coax, not the signal coming over the air. Will it boost down 200’ of coax? I will try it on the ground first, but last resort at the antenna with a power wire running up the tree.
# Posted: 26 Mar 2026 09:51am
Got this a week ago. Since building the cabin, I’ve been digging through my box of leftover automotive wire for all the usb/12v lights and switches. This is so much tidier, paired wire, already red and black for polarity, soft and easily stripped/soldered. 10 cents a foot!
travellerw
# Posted: 26 Mar 2026 10:28am
Quoting: paulz This is so much tidier, paired wire, already red and black for polarity, soft and easily stripped/soldered. 10 cents a foot!
Be very careful. That is Copper Clad Aluminum. It doesn't have the same amp carry capacity as straight copper. Some of it is VERY poor quality.
# Posted: 26 Mar 2026 10:48am - Edited by: paulz
Yes low amp only, LED lights and usb wires. It has a 5-7 amp rating, about half of solid copper. One test: I have solid core building wire running under the cabin to the 12v water pump. But very stiff where it connects to the pump switch inside, so I spliced in 2’ of this wire inside in open air to the switch panel. Filled the coffee pot this morning no problem. I’ll take a shower one of these days . Uses about 4 amps according to my bank meter.
# Posted: 2 Apr 2026 01:15pm
Paul. Did you get your antenna up and functional?
# Posted: 2 Apr 2026 01:25pm
Argh, Not yet. I have the coax, but I got the pull rope stuck up there and broke the branch down pulling on it. At least it missed the cabin and truck. I have to wait for my pilot friend to come back over and fly the drone up there again, I’m too much of a spaz.
# Posted: 12 Apr 2026 09:01pm
Just got this lp fired drip coffee maker. I’ve been using an electric Mr. Coffee but it draws 1500 watts and first thing in the morning I can’t spare the watts. This one you just put on the burner. Tried it and got the wife’s smile of approval. 15 bucks on Amazon.
# Posted: 12 Apr 2026 10:04pm
That's cool. Especially if the wife approves.  I still have a few percolators floating around. Even an old coffee boiler, if you like your coffee in bulk. Lol IMG_20260412_204452..jpg
|  The "Boiler"
# Posted: 13 Apr 2026 10:16am
Sweet. As usual I’m the last to figure it out. Made a pot on the new machine this morning, quick and easy. The instructions say no longer than 3 minutes after boil. Tastes a bit weak. I used 3 tablespoons of drip coffee and no filter. Maybe I’ll try more or longer.
# Posted: 23 Apr 2026 12:02pm
Tried to pump some 30w through yesterday, wouldn’t do it. Guess gas/water about it.
# Posted: 23 Apr 2026 04:39pm
Darz, we used to keep a boiler like that full of water on the wood stove in season, always had hot water for any purpose.
# Posted: 23 Apr 2026 05:47pm
 Yessir. They hold a good amount of water.
# Posted: 7 Jun 2026 03:41pm
Picked this up at HF. Already had the battery from other Bauer junk. Works good, not as powerful as a full size power washer but good enough around the cabin and super simple. Charge the battery and a bottle of soapy water and off you go. IMG_7230.jpeg
# Posted: 7 Jun 2026 05:44pm
That's a good deal Paul. I bought a hydro shot worx quite a few years back. They are super handy to grab for a quick wash down.
# Posted: 7 Jun 2026 08:46pm - Edited by: gcrank1
I have a Menard's Masterforce 20v? bat-op tool set and got an add on pressure washer. Same bat-packs and water supply can be house hose or out of any container but a 5 gal. bucket works well. As said, it's not a 'real' pressure washer but has been handy and from bucket useful at the cabin.
# Posted: 9 Jun 2026 07:43pm
Yeah this new pressure washer came with a 20’ hose for 5 gallon bucket work. Today I cleaned the cabin windows, of which I put in many to feel partly outside always. Best thing is a Windex bottle screws right on, on the garden hose thread I guess. Emptied that Windex too quick, need more.
# Posted: 9 Jun 2026 09:43pm
On mine a 2 litre soda bottle will screw on, also the hose that will go in a bucket, or it has a float so you can throw it in the lake if you're boating or jet skiing. Maybe see if a 2 litre bottle will fit on yours too. IMG_20260609_203939..jpg
# Posted: 10 Jun 2026 02:27pm
Good idea, got one here. Now if I could remember what you make window cleaner out of. Ammonia…
# Posted: 10 Jun 2026 03:17pm
Vinegar and water, or rubbing alcohol/water for winter mix. Lol
# Posted: 10 Jun 2026 03:25pm
Its all on the 'net' (my go-to now since my memory doesnt work)
# Posted: 28 Jun 2026 08:32am
Geez, who knew.. BIC lighters are engineering marvels of extreme consistency, utilizing pure isobutane, piezoelectric ignition, or a scraped-flint wheel. They use computer-vision quality checks to ensure a precise, fixed flame height. Each lighter is rigorously child-resistant while producing up to 3,000 lights. FLICK IT SAFELY +3Core TechnologiesFuel Engineering: The lighters contain pressurized pure isobutane, which maintains a stable vapor pressure over a wide range of temperatures. This enables a steady flame, even when held at a 45-degree angle. Amazon.comFlame Optimization: During assembly, BIC uses sophisticated computerized camera equipment to precisely measure flame height for consistency. FLICK IT SAFELY
In my quest to reignite the morning wood stove, i broke a bic lighter open. Not easy, they are tough, and highly pressurized.
